Modify Tunnel Hop Limits
Modify tunnel hop limits to update hop-limit values on previously configured tunnels.
The tunnel hop limit configures the value of the time-to-live (TTL) for IPv4 packets.
Modify the hop limit for tunnel ID 5:
Switch:1(config)#ipv6 tunnel 5 hop-limit 200
Variable definitions
Use the data in the following table to use the ipv6 tunnel command.
Variable | Value |
<0–255> | Configures the maximum number of hops in the tunnel. The default value is 255. |
<1–2000> | Specifies the tunnel ID. |
